Vawt update | 34 comments (34 topical, 0 editorial)
Re: Vawt update (3.00 / 0) (#9)
by thefinis (thefinis@hotmail.com) on Tue Nov 6th, 2007 at 05:01:24 AM MST
Not sure of what the finished size was, probably could look it up but I don't think that the output was that far out of line. The style you built was mostly a drag type so you only get to figure in about half the frontal area. With it being hard to match an alt to the low rpms and losing about half ot your swept area see how the output stacks up to a hawt 1/2 the size.
The low rpms is the killer and the fact that the vawts tend to not take advantage of higher winds cause they seem to be self limiting. I think that may be caused by the cylinder shape so they start to flow the air around them when the turbulence caused by the blades gets very high especially in the stronger winds. The turbine starts to act like an airfoil and some of the energy of the wind is diverted to create a force at 90 degrees to the oncoming wind. The side which spins in the same direction as the wind is the bottom of the air foil and the side which spins into the wind is the top of the air foil. Magus effect.
Hey you never know what will happen till you try. I think it looks great. My barrel vawts are a big success but only as yard art. I have 3 orders to fill by Xmas. No energy made just spinning eye candy.
Have fun learning
Finis
Texas born and bred
Re: Vawt update (3.00 / 0) (#10)
by electrondady1 on Tue Nov 6th, 2007 at 07:39:24 AM MST
it's got a swept area of of only 9.6 sq. ft.
so for a direct comparison with a hawt,use a blade lenth of 1.75 ft
we all know that a drag vawt at any given moment is less efficient than a prop.
that's a given.
 but we can compare it over time and factor in it's ability to work well in turbulent
air and with directional shifts.
i would very much  like to see you build a single phase stator for this mill.
with a coil for every pole.
that should bring your cut in speed way down and boost your amps.
