I'm not sure if this is true but... I thought of this and it makes sense.
Total weight of a blade isn't the critical part. Its where the most mass is on that blade. So 2 blades can weigh the same but the tip be heaver on one than the other(then the root is lighter than the other). This would make it possible for 2 blades to weigh the same but yet be different. What I think should be done rather is to weigh using 2 scales, 1 on each end. This would eliminate that and you can tell the relitive weight of each end.
Also.. just putting them on the hub and then balancing them will help you even them out. Adding weight or taking it away weight.
2 grams isn't much. I doubt it will make a big differenc. But then again I could be wrong.
-Randy
