Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
Heat from the Shower Drain
23
comments (23 topical, 0 editorial)
Re: Heat from the Shower Drain
3.00 / 0
#15
by Drawbar (
tsj5874@yahoo.com
) on Sun Dec 16th, 2007 at 05:48:46 AM MST
User Info
http://www.railroadmachinist.com
I don't think the stainless steel idea would work. Stainless steel is very poor when it comes to heat transfer. Maybe I am out of line on this, but my experience as a machinist and fabricator, I know stainless does not transfer heat very well. That is why it is so hard to machine, and why it warps so badly when its welded. It just does not conduct heat. Perhaps with this little amount of heat though, and from the way the water is sitting there, it would work, so I could be wrong.
Parent
3.00 / 0
#16
by desertcoyote on Sun Dec 16th, 2007 at 10:54:21 AM MST
User Info
I am not buying the vertical pipe method of heat transfer. And 50% recovery in this type of mode is not realistic, not at all. Maybe with capillary tubes in a laboratory under ideal conditions. Drains get coated with scum, hair soap... that alone would kill the thermal impedance and the idealized notion of the water spinning on the outside. It would be a fun physics problem to come up to a steady state solution assuming that the incoming water is getting heated by a percentage of the heat going down the drain. The most practical is the bath tube, let the water stand and cool down to the ambient. Otherwise letting the water flow into a plastic 55 gallon drum thereby heating the crawl space or basement could be workable. Entropy happens, .... use less hot water, take shorter showers!
Parent
3.00 / 0
#17
by ghurd on Sun Dec 16th, 2007 at 11:28:08 AM MST
User Info
The PDF says 25 to 31% over 1 year in a real life test.
"Make", not buy.
Parent
23
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
