Insulating on old house | 14 comments (14 topical, 0 editorial)
Re: Insulating on old house (3.00 / 0) (#5)
by Birdmmjb on Sat Dec 15th, 2007 at 07:17:42 PM MST
I agree that every bit adds up.  Thats why I want to insulate even if it settles over time its better than not doing anything at all.
As to what type of insulation I was thinking the cellulose type would do the best for this house.
All the other information I have ever seen had the holes for blowing at the top of the wall so the idea of inserting a tube at the bottom was new to me.
I still have no idea if the product I see at the lumberyards labled for attic is the same stuff for wall insulation.
My daughter will be here for Christmas and I see when she can help me with this project.
Jan
Re: Insulating on old house (3.00 / 0) (#7)
by mikeyny on Sat Dec 15th, 2007 at 07:38:15 PM MST
There are several different grades or mix's of cellulose. The Attic type is considered a low dust formula because it is blown into an open attic area. It is generally more money that the regular formula. So it really is the same product, just a little less dusty.
                                      mike
"I thought I made a mistake but I was wrong"
Re: Insulating on old house (3.00 / 0) (#8)
by elvin1949 (elvin1949@yahoo.com) on Sat Dec 15th, 2007 at 11:00:32 PM MST
Jan
 My house in Louisiana was built in 1945.
It has fire blocking every 2 ft up the walls.
It had a brick fireplace.Ashly wood heater now.
 My daughter's house in Oklahoma in was built 1943.It has gas heat. It has 2 fire blocks in every wall.
 So check your walls for fire block's before
you make up your mind what to do.
 I watched an old house get blown in insulation
one time .they had to drill lot's of hole's on the outside of the house then plug them after they were done.But it did do a good job of making it easier to heat and cool.
Elvin
