Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Rants & Opinion
Diaries
Our Products
Insulating on old house
14
comments (14 topical, editorial)
Re: Insulating on old house
3.00 / 0
#6
by mikeyny on Sat Dec 15th, 2007 at 07:29:15 PM MST
User Info
hello,
I have been in the cellulose insulation biz for many yrs now. Everything you say about the insert tube method is absolutly correct. That is the best way to do it. The only detail left out is having the proper air setting for the particular machine you are using. that can be tricky. The proper air setting determines the density of the insulation. Naturally if you run into fire blocking you need to drill holes above and below them. Also many older houses are of balloon construction or post and beam. Some have endless cavities to blow into and others have knee braces in all of the corners and some in between. Blowing cellulose can be tricky but with a good bit of research and some guidance from some pro's, some handy folks can do a respectable job.
Michael Kortz,
albanyinsulation.com
"I thought I made a mistake but I was wrong"
Parent
14
comments (14 topical, 0 editorial)
create account
How to use the board
FAQs
search the board
Google search the board
Old Otherpower Board
