US To Extinguish (Most) Incandescent Bulb Sales By 2012 | 42 comments (42 topical, editorial)
Re: US To Incandescent Bulb (3.00 / 0) (#36)
by DamonHD (d@hd.org) on Sun Feb 3rd, 2008 at 12:33:20 PM MST
And there are CFLs (compact fluorescents) that do work on dimmers, though I haven't looked hard since I'm no fan of dimmers myself!
Re: US To Incandescent Bulb (3.00 / 0) (#37)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sun Feb 3rd, 2008 at 05:20:00 PM MST
There are currently two brands that produce a dimmer-capable  CFL
http://www.taunton.com/finehomebuilding/how-to/qa/compact-fluorescents-bulbs-dimmers.aspx?nterms=657 58
Phillips now makes a CFL with only 25% of the mercury content of the cheapest and most common CFL's (I've heard that "mercury-free" bulbs are coming soon, due to demand.
http://www.greenerbuildings.com/news_detail.cfm?NewsID=34914
Some bulbs now come with a shatter-resistant plastic cover. Commonly found in outdoor applications they are referred to as "capsule CFL's". They could easily be used in a childs room.
http://www.goodmart.com/products/213619.htm
Re: US To Incandescent Bulb (3.00 / 0) (#38)
by Electron Skipper (emnefairAHTecenetDUTcom) on Sat Mar 8th, 2008 at 09:48:03 PM MST
It is ironic that common sense flies out the window when the matter of CFL's come up.  (This one is lengthy as I do hit some volumes of detail.  The most important paragraphs are the last 5 paragraphs.)
As a replacement for incandescent lighting- sure, BUT Most of the US has a heating season.  What that means is there will be a net zero change in energy consumption in the long run- that heat entering the domicile via incandescent lighting means less heat the heating plant has to produce.  Remove those incandescents for energy efficient bulbs- people will see the savings on their electric bill unless they have electric heat.  Everyone else will likely use as much other energy form used for heat as those light bulbs produced.  For some- not an issue.  But then comes disposal.
If people are truly concerned about environmental impacts, make the switch now to LED lighting- no mercury.)  CFL's would not ever come up again as an option if their EOL impacts were considered first.  This change for LED lighting has only really come about within the last 6 months.  LEDs are the future, and one industrial supplier has broken the light output barrier if you want to call it that.  In one case, a thousand Lumens from a single die, and a Power LED Xlamp capable of 100+ lumens output from one Watt input.
Drop a CFL- what happens?  Granted, mercury is bad- it is the only metal with a vapor pressure, and oxidizes so readily that an oxide layer forms on amounts that can exist as a nodule.  A teaspoon of mercury if not oxidized, could a lecture hall full of people within an hour otherwise.  The amounts used in florescents is so miniscule it vaporizesand oxidizes the moment the envelope breaks.  But that mercury vapor released, while not immediately a problem, does add up in the atmosphere and can precipitate out in rain.  So why contribute to that amount by buying CFL's?  They may be reasonably cheap now- but end of life?  How about light output after a month or two?  In some cases, there is a noticable amount of loss.
Drop an LED array, it may crack in some designs, or it may bounce in others.  Is there any contamination?  Nope.  Then there is the matter of End Of Life?  50,000 to 100,000 hours later- work it out.  That would be a decade from now or longer if left on all day and night, and with even less energy consumed.
Consider in your home- how much storage space do you dedicate to storing your items that reached their EOL?  Then consider a 5 Watt Power LED is about the diameter of a US quarter, and maybe 1/4 inch thick.  This means more room in your closet for EOL items.  Then consider what impact on storage space occurs in an office or institutional environment of 100,000 square feet?
While the technology still has a ways to go- it is at a useful stage now for true consideration and CFL's lose horribly in this discussion.  Compare 50,000 hours of an LED to the life expectancy of a CFL- the CFL loses at a mere 6000 to 8000 hours.  Then figure time required to replace each one times ten- Now figure Union Scale on that too.
Dimmability is easier with LEDs too.  CFL's and all florescent tubes can be dimmed via "Pulsed Width Modulation."  In the case of the cited CFL's above- they utilize this technique, and it is resident in the control chip on the circuit board in the base.   A number of manufacturers of that chip use the PWM method for dimming.  (It is also used for stepping up the voltage in cell phones to drive the LED flash module in cell phones.  It is also the fundamental principle for switchmode powersupplies.)
LEDs can be dimmed with PWM, it is less energy consuming than linear regulators or rheostats, therefore more efficient.  Isn't that the real goal?
CFL's are not an answer- just a transitional technology.  Transformer supplies for LED lighting on 120VAC kills the energy savings potential that exists dropping them to the same level as a 2 tube trougher.  The solution I am using in my transition is to supply from a surplus switchmode supply from a computer printer, or other device.
But with all this said about the alternatives- what really happens is the incandescent light bulb will now be the target of social engineering taxation.  All for show, as it is largely going to be a zero sum discussion about the incandescents "wasteful nature."  If you heat with alternative energy already- it is not that big of a deal.
30 KiloWatt Brats anyone?
48-volt LED link (3.00 / 0) (#39)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Sat Mar 8th, 2008 at 10:42:49 PM MST
Hope this isn't too much of a thread drift, but...
The electric bicycle forums are very interested in getting as much LED light as possible from as few Watts as possible when riding at night. 48-volts is a common battery value there. Here's just one discussion of many, use the search function at the top right for more if this type of discussion is valuable to your project.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=2951&st=0&sk=t&sd=a&hilit=l ed%E2%80%A6
Re: US To Incandescent Bulb (3.00 / 0) (#41)
by Tach on Fri Aug 29th, 2008 at 08:30:08 PM MST
 This is a great post and you are right. Most of the time the gain from installing a CFL is Zero, but there are some advantages. An incandescent light bulb is really a heater that gives off light, not a light that gives off heat. In either case it is 100% efficient. It depends on what you want. Heat or light. In the winter time for instance a CFL would be better used on the exterior of the house where most of the energy consumed is transferred into light, not heat. In summer when your a/c is running a CFL would add less heat gain to the home than an incandescent bulb. In winter it makes no difference, as you stated.
Re: US To Incandescent Bulb (3.00 / 0) (#42)
by DamonHD (d@hd.org) on Sat Aug 30th, 2008 at 02:16:38 AM MST
I'm sorry but it is not true unless (a) you heat your house by electric resistance heating rather than any of the more efficient/cheap alternatives such as natural gas, wood, heat-pump, etc, etc, and (b) you really really want to heat the space above the bulb rather than, for example, near your feet.
As an example, in the UK, per kWh of heat, natural gas is about 3 or 4 times cheaper than electrical resistance heating, never mind about half the CO2 emissions (190g vs 430g typically), so heating by light bulb is many many times less effective and more environmentally destructive than the most common (natural gas) alternative.
Plus gas central heating puts the heat nearer the ground where it's needed and delivers that heat better.
Other then for very specialised applications such as incubators and some hot foot displays for example, if you want light get an efficient light sources such as CFL or LED; if you want a heat source, get an efficient heat source such as natural gas or a heat-pump.  Don't use an incandescent light bulb which is neither.
US To Extinguish (Most) Incandescent Bulb Sales By 2012 | 42 comments (42 topical, 0 editorial)
