US To Extinguish (Most) Incandescent Bulb Sales By 2012 | 42 comments (42 topical, 0 editorial)
Re: US To Incandescent Bulb (3.00 / 0) (#42)
by DamonHD (d@hd.org) on Sat Aug 30th, 2008 at 02:16:38 AM MST
I'm sorry but it is not true unless (a) you heat your house by electric resistance heating rather than any of the more efficient/cheap alternatives such as natural gas, wood, heat-pump, etc, etc, and (b) you really really want to heat the space above the bulb rather than, for example, near your feet.
As an example, in the UK, per kWh of heat, natural gas is about 3 or 4 times cheaper than electrical resistance heating, never mind about half the CO2 emissions (190g vs 430g typically), so heating by light bulb is many many times less effective and more environmentally destructive than the most common (natural gas) alternative.
Plus gas central heating puts the heat nearer the ground where it's needed and delivers that heat better.
Other then for very specialised applications such as incubators and some hot foot displays for example, if you want light get an efficient light sources such as CFL or LED; if you want a heat source, get an efficient heat source such as natural gas or a heat-pump.  Don't use an incandescent light bulb which is neither.
