Newbies 1st PMA | 7 comments (7 topical, editorial)
Checking my Math (3.00 / 0) (#7)
by TheCasualTraveler (a.miklos@yahoo.com) on Wed Jan 2nd, 2008 at 06:23:51 PM MST
Well, my first mill is off and flying and I have mixed emotions. On the one hand my goal was to produce a working PMA no matter how small the power. I just wanted it to work so I could experiment with it and learn more and it did in fact work right from the start. On the other hand I naturally wated it to perform better than I hoped for and of course it performed well below what I expected. No matter. I wanted to learn so now I am analyzing it and going over the math. If anyone can take the time to check my numbers I'd appreciate it. I listed most of the specs in the first post of this thread, I will repeat some.
There are 9 coils, 3 phases wired star. Each coil is 120 turns of #22 wire and weighed in at 70 grams. That makes 210 grams per phase.
210 grams = .463 lbs. per phase.
#22 wire has approx.,  .195 lbs per 100'
#22 wire has 1.614 ohms per 100', so
  1. phase = appro. 237' of wire
  2. ' of #22 wire should have about 3.83 ohms of resistance.
Now here I'm less sure but at 12.4 volts and 3.83 ohms 1 phase should put out something like 3.24 amps max?
Now to figure how many amps the PMA can put out do I multiply 3.24 x 1.7** ?
We have had 10 to 20 mph, fairly steady winds for the last 2 days, what I think would be optimum conditions for testing, and this thing put out about 1.64 amps max. and mostly around .33 amps. I was hoping to see 20 to 50 watts and what I got was 4 to 20
I know this newbie stuff makes you guys nuts but I'm really trying here. Let me know what you think.
Andy
Newbies 1st PMA | 7 comments (7 topical, 0 editorial)
