Drainback to protect against overheating | 25 comments (25 topical, 0 editorial)
Re: Drainback to protect against overheating (3.00 / 0) (#12)
by DamonHD (d@hd.org) on Mon Dec 10th, 2007 at 01:27:09 PM MST
For the current house it's probably hopeless, but I can tell you that PVGIS (http://re.jrc.ec.europa.eu/pvgis/apps3/pvest.php) suggests:
886Wh/m^2/day at about our roof pitch (36*) and 944Wh/m^2/day on a vertical surface in December south-facing, with year round averages of 3100Wh/m^2/day and 2180Wh/m^2/day.
I think that those numbers are roughly halved on east- and west- facing pitches, though tubular collectors may do better than that suggests because of their profile.
I don't know our exact roof pitch, but by eye 36* isn't far off.
The north-south ridge of the roof is roughly 5m long and the house front to back (ie east to west) is about 8m.
Re: Drainback to protect against overheating (3.00 / 0) (#13)
by fcfcfc on Mon Dec 10th, 2007 at 03:05:27 PM MST
Hi: Boy, that is tough. You could run two down the East slope and two down the West slope facing true South but your roof is about 10 degs to steep, to much shading. You could only use that approach if you mounted all the way at the South end of the house so the shading problem goes away except the whole rest of the roof will then be in the shadows of the thermal units, not good for PV. That would give you 120 tubes which would yield about 100,000 to 120,000 Btu's on a perfect solar day, which would get you part way there. I suppose you could put some PV on the North end facing south but you would have to raise them up a bit for shading issues.. Not an easy install either way....
Re: Drainback to protect against overheating (3.00 / 0) (#14)
by DamonHD (d@hd.org) on Mon Dec 10th, 2007 at 03:54:32 PM MST
Hi again,
Interesting.  Thanks for that.
I think the situation is not at all good for this house for real RE.
Really time to look for a better place I think...  B^>
