Front Page
[Homebrewed Electricity
(wind)
(solar)
(hydro)
(steam)
(controls)
(storage)
(mechanical)
Classifieds
Site News
Everything
Newbies
[Remote Living
(housing)
(heat)
(light)
(water)
Reviews
Diaries
Our Products
Secure those turnbuckles!
19
comments (19 topical)
Re: Secure those turnbuckles!
3.00 / 0
#16
by
23skadoo
on Sun Mar 18, 2007 at 09:44:43 PM MST
I have also purchased one of these Chinese turbines. I had to balance and trim the blades, replace the controller, replace the turbine bearings and give it a good coat of durable paint. I did not use the supplied pipe tower. As mentioned a good unit to learn about wind generation and associated subjects. After a lot of work it is now running well. The attatched site gives some good information.
http://www.ecoinnovation.co.nz/links.php?code=8
Parent
3.00 / 0
#17
by
jimovonz
on Mon Mar 19, 2007 at 02:54:13 AM MST
Hi 23skadoo, what model do you have and what sort of output are you seeing?
Parent
3.00 / 0
#19
by
23skadoo
on Sun Mar 25, 2007 at 08:28:14 PM MST
The turbine has no markings except the name Greenpower on box. It was purchased from Jaycar electronics in Australia. The maximum output I have seen is 360 watts.
It seems to spin fairly fast to get above the 24v of the batteries then the output current rises fairly quickly. I would like to see it charge at lower RPM so I am thinking of using a step up transformer at the 3 phase output. A 25% increase in input voltage to the control box would make it a lot more efficient. Not sure if this would work in practice but it would be the easiest fix I can think of.
Parent
19
create account
How to use the board
FAQs
search the board
Google search the board
