Secure those turnbuckles! | 19 comments (19 topical)
Re: Secure those turnbuckles! (3.00 / 0) (#3)
by Phssthpok on Tue Mar 13, 2007 at 07:32:35 PM MST
A little off topic, but I have a question about those turnbuckles in your photo.
It's kind of hard to tell but it looks like the bottom portion of the turnbuckle has a 'hook' where it's attached to the anchor. Is that correct?
The reason I ask is that I can get turnbuckles for free at work (scrap) but there's a hook on one end, and I wasn't sure if this was generally accepted as safe. It is possible to get some extras, ans swap over the hoop end, but even though they're free, they're a bit of a pain to actually salvage.
Re: Secure those turnbuckles! (3.00 / 0) (#7)
by snuffy on Wed Mar 14, 2007 at 12:03:29 PM MST
I think you will find the threads backwards if you try to swap ends with the hook.
Re: Secure those turnbuckles! (3.00 / 0) (#8)
by jimovonz on Wed Mar 14, 2007 at 12:54:31 PM MST
Yes, thats a hook end attached to the anchor. I wouldn't like to comment on the reliability of these compared to '2 x eye' turnbuckles, but I have always used them and it has not been an issue so far...
As the opposing ends of a turnbuckle have opposite threads I think you will have trouble swapping ends - maybe if you have turnbuckles made by different manufacturers you might have some luck.
Re: Secure those turnbuckles! (3.00 / 0) (#9)
by BT Humble on Thu Mar 15, 2007 at 01:55:38 PM MST
You can always weld a short piece of rod across the hook to make it into an eye.
That's what I'm going to do with the 8 turnbuckles on the tower in Vanuabalavu, anyway.  I'm not happy with the way I left it last year:
http://www.smallsolar.org/success/mar2006/
BTH
