Treadmill motor / generator in the air at last ! | 21 comments (21 topical)
Re: Treadmill motor (3.00 / 0) (#13)
by CmeBREW on Thu Mar 08, 2007 at 03:46:34 PM MST
Hey GerryS,
  I am currently working on 'PART 2'. You will see in the photes how i mounted the rotor to the fan spindle and so on very shortly. -good questions ,Thanks
Re: Treadmill motor (3.00 / 0) (#15)
by GerryS on Fri Mar 09, 2007 at 07:20:04 AM MST
Can't wait to see.  If you used the front part of the treadmill, is it a fan?  Then it just screws onto the shaft.  But I guess you've got to make sure that it doesn't spin in the direction of unscrewing but only screwing on.  driling holes through the fan disc to mount the hub to is easy enough. I'll be lookin to see how you do it!
