Treadmill motor / generator in the air at last ! | 20 comments (20 topical, editorial)
Re: Treadmill motor (3.00 / 0) (#15)
by GerryS on Fri Mar 9th, 2007 at 07:20:04 AM MST
Can't wait to see.  If you used the front part of the treadmill, is it a fan?  Then it just screws onto the shaft.  But I guess you've got to make sure that it doesn't spin in the direction of unscrewing but only screwing on.  driling holes through the fan disc to mount the hub to is easy enough. I'll be lookin to see how you do it!
Treadmill motor / generator in the air at last ! | 20 comments (20 topical, 0 editorial)
