Treadmill motor / generator in the air at last ! | 21 comments (21 topical)
Re: Treadmill motor / generator in the air at last (3.00 / 0) (#17)
by CmeBREW on Sun Mar 11, 2007 at 06:11:28 PM MST
Hey Gotwind,
yes, the blades are modified some. I impravised- used own judgement,etc. -Since these blades are so short, I had to go with steeper angles for purpose of start-up. I am still in need of learning more about tsr though. But I must be in the ball park, cause these blades are doing terrific. That airfoil shape is AMAZING. Even in a little 10 Mph tiny wind they take off like an airplane propeller. And to think just last fall I was experimenting with flat 1/4" plywood blades on that same motor.(Im emmbarrased now) I could only reach 10v in a hurricane wind! Anyway as I said in the post, 4 blades would've been even better for the winter months. The cold temperatures outside make the grease in the ball bearings alittle thicker, which means alittle more difficult starts -- and with only a 4 ft rotor , 4 blades would start up better on those 10mph cold wind days. Now that we just had two 50 degree F days, the 3-blades starts up even easier now since the grease in the bearings is warmer. On a warmer day it starts up many many times on a common 10mph low wind day.(since the breeze frequently stops and goes)
Re: Treadmill motor / generator in the air at last (3.00 / 0) (#18)
by CmeBREW on Sun Mar 11, 2007 at 06:26:58 PM MST
I always forget to say stuff. sorry. I also know it would do better with 4 blades, because I did experimenting with a 'jump-start' wire to my positive bus bar. The generator is normally a motor, so when there was a good enough small wind (probabley 10mph) I would 'jump start' it for a few seconds, and it would take off, spin and generate for a minute or two and then stop again due to the breeze dropping off. Of course i,m not going to sit there and 'jump start' the thing all day to get alittle power--but clearly 4 blades would have been perfect and helped in braking in very high winds. 4 blades probably would have cost alittle power of the top end, but I doubt too much.
