Treadmill Motor / Generator in Air ( PART 2 ) | 16 comments (16 topical, editorial)
Re: Treadmill Motor / Generator in Air ( PART 2 ) (3.00 / 0) (#8)
by wooferhound (tim((NoSpamAt))wooferhound.com) on Fri Mar 9th, 2007 at 04:43:48 PM MST
You said that you are weather proofing with 5 minute epoxy
But 5 minute epoxy is not waterproof . . .
W o o f -={(
Re: Treadmill Motor / Generator in Air ( PART 2 ) (3.00 / 0) (#9)
by CmeBREW (smke833f@hotmail.com) on Fri Mar 9th, 2007 at 05:12:42 PM MST
Hello Wooferhound:
I am no Genuius on epoxy or 'waterproofing' but I had thought I read from the group that epoxy was more water resistant than fiberglass resin. If it isn't , then what is???  Hopefully, it will be good enough and last awhile.
Epoxies (3.00 / 0) (#10)
by wdyasq on Fri Mar 9th, 2007 at 06:33:59 PM MST
I was told by a major epoxy formulator/fabricator "5 minute epoxy" is not really an epoxy.
The 'waterproofness' of a resin has a lot to deal with how they are formulated, i.e. what is added to the basic resin.
Nice work.
Re: Epoxies (3.00 / 0) (#11)
by vawtman (vawtman(at)charter(dot)net) on Fri Mar 9th, 2007 at 07:16:13 PM MST
Ron ,For bonding long cure epoxies are what you look for.For sealing lots of stuff out there.
  Love to trip that horsie.
Re: Epoxies (3.00 / 0) (#12)
by wdyasq on Fri Mar 9th, 2007 at 08:00:15 PM MST
I'd want to know the use of the resin - 'WTF are your trying to do?' From there one might get an idea. I tend to use products made by major suppliers and either known by me or a trusted friend to be a good product. Curing time, allergic reaction, hardness, temperature sensitivity, adhesion to materials and several other factors are considered.
Techniques used are those proven and have previous testing/experience. All of this is combined to make a good guess at something with the hope I got everything right and won't need to redeaux the project. MANY times a prototype is built just to get a technique right or test a theory on method or strength of doing a project.
But, then again, I'd rather not do a job or project than get someone hurt or killed. I err on the side of sanity and tend to respect the success, and failures, of others as a guide.
Re: Epoxies (3.00 / 0) (#13)
by nothing to lose (nothingtolose175 at yahoo.com) on Mon Mar 12th, 2007 at 05:25:33 PM MST
Ron,
You have good point abot epoxy if mounting blades to a hub with epoxy, or glueing the genny to the tower 100' up, neither would I do with expoxy though of course.
BUT when all you want to do is shed direct rain to keep water out, WHO CARES??
Heck wrap an inner tube around it and hold in place with large hose clamps, not like it's any saftey issue!
Treadmill Motor / Generator in Air ( PART 2 ) | 16 comments (16 topical, 0 editorial)
