NTL Designed blade hubs | 12 comments (12 topical, editorial)
Re: NTL Designed blade hubs (3.00 / 0) (#3)
by dalibor (mdalibor - at - gmail - com) on Sat Apr 14th, 2007 at 09:08:57 AM MST
i am interested to see how your`s one blade hub and blade will get together.
you do need opposite weight to keep balance, am i wrong?
that SUPER 6 looks like a good idea for experimenting, nice job indeed . just add a   blade or complete of them  to start it on lower speeds of wind :-).
with that 1/8 thick steel, what size of blade would be maximum? including also other measures, of course.
Re: NTL Designed blade hubs (3.00 / 0) (#5)
by nothing to lose (nothingtolose175 at yahoo.com) on Sat Apr 14th, 2007 at 04:30:52 PM MST
"with that 1/8 thick steel, what size of blade would be maximum?"
Far too many variables to actaully say. I think in normal use your motor shaft or blades would be more of a limiting factor than the hubs.
Say PVC blades you could make so long they flop like a wet noodle, but won't hurt the hub.
Large or heavy enough wood blades I think the motor shaft would bend as a weak point durring yawing force before anything else would give out. If a person was using real large/heavy wood blades I would use 2 hub plates to prevent any flexing. With a front and rear blade hub and wood blades in between I dought anything close to within reason would ever hurt the hubs.
Re: NTL Designed blade hubs (3.00 / 0) (#6)
by kenputer on Sat Apr 14th, 2007 at 05:45:37 PM MST
Hi NTL,
  I am waiting for one of your 3 blade hubs and have send you some info on the kind of hub adpt. I plan to use. Hope the info is helpful to you.
Ken
Re: NTL Designed blade hubs (3.00 / 0) (#8)
by nothing to lose (nothingtolose175 at yahoo.com) on Sat Apr 14th, 2007 at 08:42:40 PM MST
Yes, thanks Ken.
 I just found the info e-mail
I found several other items on their site I may have an interest in as well as an Adpt. I may like.
E-mail me when you get your hub. I am wondering how long it takes to get to you there.
NTL Designed blade hubs | 12 comments (12 topical, 0 editorial)
