My generator | 5 comments (5 topical, editorial)
Re: My generator (3.00 / 0) (#3)
by johnlm on Wed May 16th, 2007 at 05:32:59 PM MST
SuperF,
Upon looking at the site you bought the PMA from, you will notice that they show curves of open circuit voltage and short circuit current.  You will not get the 87 V output at the 11A short circuit current.  You will not be able to get more (and will get less) than the 10 or 11 amps into a battery at any reasonable RPM you can get out of your 5 ft prop. - except possibly if you leave it running in very high winds.  The correct way to calculate the power would be to multiply the charging battery voltage (say 14V) times the charging current of 10 amps to get 140 Watts.  I suspect you may only get up to 125W max out of that PMA after all the other losses are factored in.  In order to get 12V out at 150 RPM they had to rewind the stator with fairly small wire (AWG 22 maybe) to get enough turns (around 300 turns per phase)to get that output.  And the output current is limited by the resistance of the small diameter wire and the reactance of the core.  There is nothing wrong with this, just that it is not a high power PMA.  Ive rewound and rebuilt the armatures with NEOS on many of these alternators and get results similar to what the alternators on that site gets.  If all you are looking for with a direct drive prop is around 100W on that PMA it will probably do it.  The other models they advertise have fewer turns of larger diameter wire and will get more power, but require some gearing up (belt drive) to achieve 12V in reasonable low startup (7mph) wind speeds.
I am curious, how much does the alternator cog when trying to start it?  At what wind speed (approximately) does it start turning over?
Johnlm
Re: My generator (3.00 / 0) (#4)
by TheSuperFantasma (Feliperey74@hotmail.com) on Thu May 17th, 2007 at 08:08:57 AM MST
John,
You just killed all my hopes on this generator! I was hopping to power my entire home with this windmill.
: (     Just kidding!
Nando had already told me not spect much power out of this unit. I just hope to get enough power from it to have a light outside in my front yard. My wife will kill me if I do not get this thing to work.
Start at about 7 - 9mph.
Thanks for your comments!
TheSuperFantasma
Re: My generator (3.00 / 0) (#5)
by johnlm on Thu May 17th, 2007 at 04:42:45 PM MST
Looks like you are well on your way to getting it all done.  If you pull it down one of these days, it would be nice to see a picture of the head / tail vane mounting assembly.  From what I can tell fron the long shots it looks intrestingly different than the standard approach used by most of the folks building dual rotor heads.
I used a modified auto alternator one summer to keep the battery on my camp trailer up in the mountains charged up.  I replaced it with a solar panel last summer for less worry in the times Im not up there.
John
My generator | 5 comments (5 topical, 0 editorial)
