Guemes Island 2007 Part 2 | 2 comments (2 topical, editorial)
Re: Guemes Island 2007 Part 2 (3.00 / 0) (#1)
by Flux on Thu May 17th, 2007 at 12:38:58 PM MST
Interesting that 6 ft machine, placing the magnets that way overcomes the problem of lack of space at the centre of the stator if you use a conventional hub. With the magnets placed that way the thing would be better with an overlapped coil design, but it makes a very difficult thing to wind.
I have built machines of this type with magnets the conventional way using a blank disc to return the flux but I built my own hub. I have suggested this construction to others but they have run into the space problem at the centre. This seems a perfectly logical solution. I suspect the matching will be quite reasonable for 6ft when loaded in the conventional way.
Nice to see that you have had lots of fun.
Guemes Island 2007 Part 2 | 2 comments (2 topical, 0 editorial)
