Steam Tube Boiler | 4 comments (4 topical, editorial)
Re: Steam Tube Boiler (3.00 / 0) (#2)
by willib (willibur at comcast dot net) on Fri May 18th, 2007 at 09:14:10 PM MST
Joseph very cool stuff,cant wait to see the turbine spinning like a bat outta hell
hey it green outside ? what happened to the white stuff :)
chad , he has a steam turbine he's working on..
Carpe Ventum (seize the wind)
Re: Steam Tube Boiler (3.00 / 0) (#3)
by spinningmagnets (velmis1450bc(at)aol(dot)com) on Fri Jul 13th, 2007 at 11:41:55 PM MST
Cool stuff! If the steam is still pretty warm after passing through your turbine, you can run it up an insulated pipe to a rooftop cistern, and once it makes a U-turn and starts heading down, you can pass it through a diesel truck aluminum turbo-intercooler. The slightest breeze will condense it back into a liquid and you'll have hot gravity-flow water on the roof.
I'm an old Navy steam guy, (used Uranium instead of wood, though) describe your turbine, please!
PS great job on the boiler and guitar!  -Ron
"NAVY: Never Again Volunteer Yourself!" -My boot camp Chief
"Close only counts in shaving and nuclear weapons" -ADM Rickover
Re: Steam Tube Boiler (3.00 / 0) (#4)
by WXYZCIENCE on Sat Jul 14th, 2007 at 12:44:10 AM MST
Ron, here is a link to the steam turbine.
http://www.fieldlines.com/story/2007/3/1/5259/19738
I am working on a injector system to replace the water in the boiler. Thanks for the input.
Joseph
Steam Tube Boiler | 4 comments (4 topical, 0 editorial)
