Using styrofoam blades for a VAWT? | 14 comments (14 topical, editorial)
Re: Using styrofoam blades for a VAWT? (3.00 / 0) (#13)
by TheEquineFencer (TheEquineFencer@AOL.com) on Sat Jun 23rd, 2007 at 04:09:25 AM MST
It's funny I found this post when I did. I have freind taking classes for his air frame lic. for the FAA. The "foam" used is not the type sold at a hardware store, it's special foam with a differant structure used for airframes. He has made actual scaled down wings using composite materials, the idea is the same though. Monday he's going to ask his instructor to see about getting large sheets and the materials to build some for me. He says the stuff is awsome! You just cut it with a hotwire and lay the resin on and then lay a section of "fabric" on top and roll the bubbles out. If you use regular foam it melts. That's my .02 worth.
F. Moore Farmville, NC
Using styrofoam blades for a VAWT? | 14 comments (14 topical, 0 editorial)
