Sensibulb LED lights | 14 comments (14 topical, 0 editorial)
Re: Sensibulb LED lights (3.00 / 0) (#2)
by la7qz on Thu May 3rd, 2007 at 07:23:25 PM MST
Hi
Thanks for the reply. Could you do a post with more information on the LED's and controllers you mention, including sources etc.? I'm sure a lot of people would be interested.
Regards,
Owen Morgan
Yacht "Magic"
Falmouth Harbour anchorage
Antigua
Re: Sensibulb LED lights (3.00 / 0) (#3)
by Norm (peppysue@suite224.net) on Fri May 4th, 2007 at 05:40:46 AM MST
   Simple just do a Google.....Cree LEDs
               LOL !
               ( :>) Norm.
( :>) Norm
Re: Sensibulb LED lights (3.00 / 0) (#5)
by la7qz on Fri May 4th, 2007 at 08:45:20 AM MST
Yes, I appreciate that Norm, but I was looking for solutions and examples of what people have actually homebrewed and got working rather than manufacturer's hype. :)
Also, with a very marginal Internet connection, searching can be a bit of a pain.
Regards,
Owen Morgan
Yacht Magic
Falmouth Harbour, Antigua
Re: Sensibulb LED lights (3.00 / 0) (#4)
by whatsnext on Fri May 4th, 2007 at 08:29:51 AM MST
I'm somewhat hesitant to post my source because I'm pretty sure he's just doing me a favor selling small qtys. Plus they are located in China and most people would never understand their rather low level of customer service. You might want to check out http://www.superbrightleds.com/led_prods.htm . I've dealt with them without a problem. The point I was trying to make is that without knowing what LEds are being used in the light you refer to, and how they are driven, it's tough to comment on the quality. Plus, technology is chsnging so fast that any product not built in the last few weeks is probably obsolete.
John.......
Re: Sensibulb LED lights (3.00 / 0) (#6)
by la7qz on Fri May 4th, 2007 at 09:58:56 AM MST
Hi
I'm afraid I have a negative experience with Superbrightleds. A year and a half ago, I bought a couple of their bayonet bulbs from another cruiser I met in the Cape Verde's (west coast of Africa). He had ordered more than he needed and was covering his costs by selling them to other cruisers.
The LED's failed within a few months, burning out in groups of three. I sent an e-mail to Superbrightleds describing the problem and specifically pointed out that I was NOT looking for a refund. I was simply asking for advice, as I was interested in replacing the bulbs, but did not want a repeat of the failure. I received a very curt e-mail where they basically said I must have used a product meant for cars rather than boats and that it was not their problem if I chose to do something so stupid.
Well, I have lived on a boat for quite a few years now, and I believe I know a bit about the electric systems of both boats and cars. The main difference between the systems is that a boat usually has more battery capacity, a higher capacity alternator to match and other (normally well regulated) charging sources in addition to the alternator.
I can not see any difference between a car and boat electric system that would affect the performance or longevity of LED bulbs. The bulbs I installed were never subjected to higher voltages than normal alternator charging in a car. Unlike a car installation, I never started my engine from the same battery as the LEDs were operated from, so there would be no transients.
I took their e-mail to mean that they did not want my business. I have decided to honour their wish.
Regards,
Owen Morgan
Yacht Magic
Antigua
Re: Sensibulb LED lights (3.00 / 0) (#7)
by whatsnext on Fri May 4th, 2007 at 10:20:12 AM MST
If this is the case then you may want to continue following Commanda's master class and hope that someone wants to take on the job of having boards built or sourcing the parts. I have a few DIY lights built with 5mm LEDs on my boat, Merit 23GP "Between the Sheets", and I've never had a failure but I just can't stand the color. I don't live aboard so I put up with it. Once Commanda finalizes the circuit you might look at the Pirahna warm whites and then build modules to fit into your existing fixtures.
Fair Winds, John
Re: Sensibulb LED lights (3.00 / 0) (#8)
by yuandrew (yu(dot)andrew(at)yahoo.com) on Sat May 5th, 2007 at 07:27:44 PM MST
This is the Cree XR-E led that many people are talking about. I read that the current generation are even more efficient now at 80 lumens/watt. The controllers are listed under "High Power LED Drivers" on the left hand side colume. They will still have a "cool white" fluorescent light type color.
http://www.besthongkong.com/index.php?cPath=19_53&osCsid=9e9a3427b1b0db2eb95d9950bb7746d2
"Always under construction"
Re: Sensibulb LED lights (3.00 / 0) (#11)
by whatsnext on Tue May 8th, 2007 at 10:08:57 AM MST
Those prices look pretty good and I'm sure those regulators would allow for dimmability. I think 80lumens/watt is maybe a tad optimistic but surely possible if you have enough heat sinking. I would think most users would want to avoid the heat and just use extra LEDs. The new generations of LEDs color shift a bit as you change drive current starting at green and eventually shifting to blue. Somewhere in the middle you get white, that's why they bin them.
John.....
Re: Sensibulb LED lights (3.00 / 0) (#10)
by 3rd Charm on Sun May 6th, 2007 at 11:48:10 PM MST
If you have a lot of scrap boards in your junk box, sometimes you can cut them up  to suit your needs, even if you have to drill some extra holes. I was looking through my junk box today with just that in mind, and low and behold.... lots of resistors too!
Sometimes it pays to strip things down before you throw it out. :o)
