My First Wind Turbine | 6 comments (6 topical, editorial)
Re: My First Wind Turbine (3.00 / 0) (#3)
by GeeMac (foxunc@telus.net) on Mon Jul 2nd, 2007 at 12:44:31 PM MST
Hi Ezee. I just got my turbine running a few days ago. It feel pretty good eh?
Tell me a bit about the magnets you used and how you wired it. I'm having a bit of trouble with the electronic part of mine.
GeeMac
Re: My First Wind Turbine (3.00 / 0) (#4)
by ezee (3z33etm -at- gmail *dot* com) on Mon Jul 2nd, 2007 at 03:05:24 PM MST
Well...I kind of cheated.  I am using one of ed lenz's "mini gens" as the heart of it, so i didn't choose the magnets or the coil, etc.  I just fitted it with some longer PVC  blades and the pvc chassis and pole.
You can learn more about the mini gen here
http://www.windstuffnow.com/main/minigen.htm
I got the one with the metal housing.
Its a low amp high voltage setup...but it shocked the CRAP out of me when I was putting alligator clips on the LED to provide a load.
I'm sure you could mod it with permanent magnets...and then fiddle with the wire size and # of turns of the single coil to tweak the output.
My First Wind Turbine | 6 comments (6 topical, 0 editorial)
