Easy Auto Alternator Conversion | 28 comments (28 topical, 0 editorial)
Re: Easy Auto Alternator Conversion (3.00 / 0) (#12)
by oztules (oztules__at__bigpond.com) on Tue Jul 3rd, 2007 at 06:56:59 PM MST
Joseph,
I think the shaft provides a much better flux path for the magnets than the air gap between the claws... effectively short circuiting the flux from claw to claw, rather than jumping the air-gap.
With the original electromagnet, the shaft "became" the magnet and the return path for the flux was across the air-gaps. The shaft in your configuration now becomes the return path instead.
Solving this problem (with a magnetically inert shaft)will increase the flux density between the claws air-gap making it  the only decent flux return path.... increasing its effectivness markedly..... new shaft looks the ticket.
good use of old alts and microwave oven Joe.
.........oztules
Re: Easy Auto Alternator Conversion (3.00 / 0) (#27)
by Slingshot on Fri Jul 6th, 2007 at 08:56:17 AM MST
That's absolutely correct.  Just making a new shaft out of stainless, or maybe even aluminum, would probably account for a tremendous increase in output.
