Easy Auto Alternator Conversion | 28 comments (28 topical, editorial)
Re: Easy Auto Alternator Conversion (3.00 / 0) (#3)
by zubbly on Tue Jul 3rd, 2007 at 02:54:36 PM MST
(User Info) www.zubbly.com
hi wxyzciense,
i was often going to try the same thing myself.  only use neo mags and replace the shaft with a stainless one.  the stock shaft in my belief, robs too much flux from the mags.  a stainless shaft, will allow all the flux to be concentrated on the claw rotor.
you went this far, maybe use the same unit with a new shaft and see what happens.
good luck,
zubbly
Re: Easy Auto Alternator Conversion (3.00 / 0) (#5)
by WXYZCIENCE on Tue Jul 3rd, 2007 at 03:17:34 PM MST
Zubbly, I will try a brass shaft and see if the output is increased. I also have some large speaker magnets to work with. Maybe build a claw 6" in diameter with more poles.
Joseph.
Re: Easy Auto Alternator Conversion (3.00 / 0) (#9)
by Ungrounded Lightning Rod on Tue Jul 3rd, 2007 at 04:30:31 PM MST
I like the ideal of a stainless shaft - or brass if it's strong enough.  But you might have corrosion issues near the join in an outdoor environment.
Other possibilities:
 - As long as you're machining the "flowers", machine out the center of (at least) one for a significant clearance (like larger than the gap between the "petals") and press in a brass insert.  Then you might be able to get away with the original shaft and still have most of your mag field unshorted by the shaft.  (You'd retain the splines in one "flower" and if the other tends to slip you can always cast it into place by filling the space between the fingers.)
 - Ditto but for brass substitute something non-metallic to avoid corrosion - like more casting material.  (Or just leave it open and count on the "petals" to center you on the magnets until it's cast.)
 - Iffy:  Machine down the shaft and press on a brass pipe.
Remember that the structure was open mainly to cool the coil.  With permanent magnets this is no longer an issue.
Easy Auto Alternator Conversion | 28 comments (28 topical, 0 editorial)
