Easy Auto Alternator Conversion | 28 comments (28 topical, editorial)
Re: Easy Auto Alternator Conversion (3.00 / 0) (#8)
by hiker (hiker.wild[at]yahoo[dot]com) on Tue Jul 3rd, 2007 at 04:17:33 PM MST
nice job.....
check out- -auto alt--on google search the board..
those auto alts just never die  :}
heres one out of many--might give you some ideas........
              http://www.fieldlines.com/story/2005/5/11/04025/3914
WILD IN ALASKA
Re: Easy Auto Alternator Conversion (3.00 / 0) (#10)
by Warrior on Tue Jul 3rd, 2007 at 05:09:51 PM MST
Joseph,
Nice work on the alt. Maybe you can try what Jerry does to get the voltage up:
Separate each phase; rectify each phase individually then series the DC outputs. Not the best use of a 3 phase alt, but at least it will make some power.
If my numbers are right you should get:
6.8 ac x 1.41 = 9.61 DC per phase x 3 =  28,83 volts DC @ 1900 rpm. At half the speed you have slightly more than 14 volts. Not bad for cheap ceramics.
As reference SWWP Air-X "Industrial" cuts in at 900 rpm ;)
Warrior
Easy Auto Alternator Conversion | 28 comments (28 topical, 0 editorial)
