pedgen stock car alt | 7 comments (7 topical)
Re: pedgen stock car alt (3.00 / 0) (#3)
by hiker on Wed Aug 01, 2007 at 03:54:35 AM MST
hey tecker..
with a smaller shaft it would be even harder to spin up to 12v with a load on it..
thats a flat belt on there..
i made a slightly bigger shaft for it[pipe]..plus i replaced the 30w headlite that
hooked to the field coil with a taillight bulb..now its a lot easyer to pedal when
theres a load on it..and i still dont need a batt to power it up..
 the more currant you apply to the field coil --the stronger the magnetic field..
not sure of the amp rating on this alt-65??--but theres no way im going to get that pedaling--so you want the amount of currant going to the field coil to be somthing you can handle--thats why i switched to even a smaller bulb--no sence in fighting all that extra drag--just for fun i hooked up a 400w 38v aircraft landing light--got way to bright to even look at--plus i had to pedal like a mad dog in heat...
not sure of what i can get out of it now--blew out most of my spare headlites..
guess ile have to borrow the amp meter off of my motorhome pedgen and find out..
its late here...heres a shot of the alt and wire hook up..
WILD IN ALASKA
