You notice how manufactures never seem to publish efficiency at low output powers ? Especially inverters. You will notice the efficiency curve dropping at a very steep slope at the left hand side (lower power side) of the power vs. efficiency graph.
And SOMEBODY has the wrong information on the MX60 meter ! The MX measures the OUTPUT, NOT the input current. It's the INPUT current that is calculated, so the output current should read closer. Maybe it got mis-adjusted somehow ?? The current is averaged in hardware and software so shouldn't make a lot of difference if there is output current ripple or smooth DC current. Most inverters will cause 120 Hz current ripple on the DC line at higher output powers.
Hope this helps shed some light.
boB[ Parent ]
