been awhile, checkin in | 17 comments (17 topical, editorial)
Re: been awhile, checkin in (3.00 / 0) (#7)
by SwedeRGB on Thu Aug 16th, 2007 at 02:57:08 PM MST
Hi Bob
Sorry but I didn't understand your efficiency readings.
When calculating the Energy efficiency i get
MX60 result 13,2*6,9/(60*3,9)= only 38,92%
Meter result 13,2*5,7/(60*3,9)= only 32,15%
Do I totally misunderstand something here?
Where comes your 83% from?
I have been working a lot with the designing of switched DC/DC converters.
and the result you are describing is a Waste.
To be honest I have newer seen any switching application that gives as high real world efficiency as
stated 98% by the MX60, but then again the MX60 is probably not switching then.
Reading the "MX60_a.pdf" it tells that the
Power Conversion Efficiency Typical
98% at 60amps with a 48V battery and a nominal 48V Solar array.
(Probably working linear at the time displaying the internal loss in RDSon.)
This really tells U nothing of the product.
A coversion table would be nice though.
The SwedeRGB
Re: been awhile, checkin in (3.00 / 0) (#9)
by bob g on Thu Aug 16th, 2007 at 03:42:03 PM MST
Swede:
those number i posted were only one shot, where we were trying to figure out
why there was a difference in output amps indicated and what was measured.
i did not mean to infer that it was at 83% efficient at that test point,
we only saw it get up to 83% efficient at the highest point as measured with two other meters, which agree'd with the measured amperage.
i am not real thrilled either with the published spec's on this product, it boarders on ... well ,,, you know!
bob g
been awhile, checkin in | 17 comments (17 topical, 0 editorial)
