Ametek VAWT failure :/ | 11 comments (11 topical)
Re: Ametek VAWT failure :/ (3.00 / 0) (#6)
by ZooT on Mon Aug 27, 2007 at 11:07:56 PM MST
Wouldn't you need more than two "cups" on a VAWT considering that when both are perpendicular to the wind it's going to want to try to spin backwards.......
And I think I've read either here or elsewhere(maybe Ed's place?) that if you're only using two cups you need to make a stack with two more on top 90 degrees  apart thus that there's at least one cup pulling all the time.......
Re: Ametek VAWT failure :/ (3.00 / 0) (#8)
by Norm on Tue Aug 28, 2007 at 03:46:50 PM MST
I think 3 blades would work better than two,
however I was under the impression that while
one 'cup' was facing the wind that is drag and
the other with it's other side is lift...much
like a sailboat can sail against the wind.
                ( :>) Norm.
( :>) Norm
