inverters | 10 comments (10 topical, editorial)
Re: inverters (3.00 / 0) (#3)
by boB on Tue Sep 18th, 2007 at 12:16:15 PM MST
(User Info) http://bob.gudgel.org
If you have a lot more time than money the building your own inverter
can be very educational and rewarding.  Do you have the necessary lab
equipment like, scope and a decent meter and soldering iron ??
Another thing you could do is to procure a 12V car amplifier and step
up transformer and then build a 60 Hz sine wave oscillator to drive
the amp with.  Then you have a sine wave inverter. After that, you could add
feedback to adjust the sinewave amplitude to get voltage regulation.
Building your own inverter WILL take time and some money and you
will most likely let the smoke out a few times. Certainly a modified square
wave inverter would be easier. Either way you have to make sure it will sink
as well as source to/from the AC load, or "clamp" to the zero crossing
for the modified square wave version.  I don't know WHY anybody would want to modify
a perfectly good sine-wave !
boB
Re: inverters (3.00 / 0) (#4)
by bob g on Tue Sep 18th, 2007 at 02:38:35 PM MST
boB:
yes i have a scope, meters and a good iron :)
and i would agree,, "why would anyone modify a perfectly good sinewave"?
lol
i also have a collection of high power parts, and also
have an industrial exide ups that is 15kwatt, 3 phase that i could canabilize for parts as well,, it has a 240volt dc front end which i have no intention of trying to feed. it has some hercan big parts in it that ought to be useful,, and maybe it could be modified for my intended use,, i dunno.
what i am wondering is
there are numerous schematics for square wave units, that seem to do the job they are intended for,, and they have internal triggering to get them somewhere close to 60 hz.  usually they use sort of a push pull arrangement to feed a transformer
what if one was to build a multistep push pull and instead of triggering the steps internally with descrete components one used a micro controller with various output pins to trigger each step.
anyone ever tried it,, or have a schematic for a microcontroller triggered inverter?
bob g
inverters | 10 comments (10 topical, 0 editorial)
