Gusts mean little - Average is everything | 9 comments (9 topical, editorial)
Re: Gusts mean little - Average is everything (3.00 / 0) (#4)
by Nando (nando37-at-tx-dot-rr-dot-com Correct theanti-spam) on Sun Sep 9th, 2007 at 09:44:03 PM MST
Dave B:
You have the watt meter already in your system and you may do it by integrating the power you have.
One way is to do One second integration or even lower times, read the peak power like every 100 milliseconds and add the values then add the times which gives you the watts per added time which you can convert into watts-hours.
You are already getting the watts samples, integrate them.
Nando
Re: Gusts mean little - Average is everything (3.00 / 0) (#6)
by Flux on Mon Sep 10th, 2007 at 03:13:09 AM MST
Yes Dave, you are right that the peak is of little value. Your data clearly shows how many of these machines survive with peak power levels well above what the winding can stand. On gusty sited where the average is very low there will be little heat in the windings. On a site with decent clean wind the average power could be much closer to the peak.
I suspect that the wind power duty cycle is normally very low and the alternators are working nearer a duty cycle associated with small welders and other intermittently rated devices.
With your heating load you have the option to match the load far better to the alternator in higher winds so stator temperature will be much less of an issue.
Also as there is negligible heat in low winds it doesn't matter much if you are well off the best operating point in low winds. A high start up speed and running in stall at the lower wind speeds will cost you very little in terms of heat produced.
If you can keep control of the thing by furling in high winds then you may not need much in the way of ideal load matching. A single fixed load is possibly being very optimistic but you may manage with it.
The thing to avoid at all cost is the temptation to add excess load in high wind to keep speed down rather than furl. If you have to do that then do it drastically enough to stall the prop and reduce power into the alternator. Don't work at the point where the prop is not stalled and you are dissipating more in the windings than into the load.
I see you are looking at capacitor series circuits. Yes, fine in theory but at low voltage and low frequency I wouldn't consider it a viable solution unless you have a source of large quantities of near free capacitors. The cost in capacitors to do it satisfactorily will be ridiculous. Electrolytics I would consider a short term solution. the only saving thing is that electrolytics generally fail to short and would be safe for the machine. They also sometimes fail spectacularly to mechanically open circuit with a bang and lots of mess so keep them in a closed container if you do play with them.
Re: Gusts mean little - Average is everything (3.00 / 0) (#7)
by Dave B on Mon Sep 10th, 2007 at 10:05:06 AM MST
Flux,
  Thank you for your reply and very useful information. I am learning as I go and it is so helpful from those who share their successes and failures here that I hope I can contribute some the same. Patience is important so that not to make radical changes too quickly based on minimal observations. This has been up now for nearly 6 weeks and I have yet to see the constant winds that will be more frequent this Fall and Winter. If I were to make some changes now I am certain I would be changing things back later on. Right now things are safe and well behaved but like you say it is tempting to tweak things and I think that is where some get into trouble (burnt stators for example). I would rather accept a little less all the time and be safe when the winds really blow (and they will) than to risk having to build again just for short term gain. I sure appreciate everyone's help, more updates to follow.  Dave B.
Gusts mean little - Average is everything | 9 comments (9 topical, 0 editorial)
