Tiny Steam Turbine | 15 comments (15 topical, 0 editorial)
Re: Tiny Steam Turbine (3.00 / 0) (#8)
by WXYZCIENCE on Wed Jan 16th, 2008 at 12:45:00 AM MST
JW, the compressor section of the turbocharger was chosen for it's weight better the lack of it. What I am up to is building a reaction stage turbine. The impulse type make to much noise. Removing the lower part of the blades, this have allowed me to use very small nozzles and achieve the expansion through the wheel that I was looking for. The alternator is directly coupled to the output shaft. It also supports the pto end. The first test with the alternator have allowed me to take the power off at these very high speeds. I suspect that the full output range will be a little lower that the max. speed of the turbine. Around 70K. If all goes according to the plan the entire unit and flash boiler will weight under ten pounds. I expect no more that marginal power output, 20 watts. Joseph.
Re: Tiny Steam Turbine (3.00 / 0) (#9)
by JW on Wed Jan 16th, 2008 at 05:16:20 PM MST
Interesting,
 So you are going to run it backwards with nozzle's. Basically you can use whatever housing you wish in that case. That would nullify the cyntrifugal aspect of the compressor/impeller your using. I cant wait to see an update, that is a cool project.
 I was thinking using a roots type blower would be more simple, for a steam type of application( the expander),but I like your idea.
JW
