Like Norm said, need to make sure the fan blade hub doesn't come loose and fall off. I use a few of the HF drill stops (50 cent coupon sometimes). May be enough room on the factory shaft? LOL. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=38336
Jerry, Some of the ECM star / delta / JR numbers never made much sense to me. (1/2HP, 500 RPM, Star or Jerry, 3.4A) Maybe Jerry Rigged with a fat motor-run cap in series with each phase before the rectifiers would help? F&P has about the same issues? In case you missed it, http://www.fieldlines.com/story/2008/9/23/8477/59397
G-[ Parent ]
Just need to get this wiring figured out so I can go forward.[ Parent ]
