Xantrex C60 | 6 comments (6 topical, editorial)
Re: Xantrex C60 (3.00 / 0) (#3)
by ghurd on Mon Oct 6th, 2008 at 03:07:48 PM MST
Simple.
Sometimes the windmill makes 1230W.
The heater only supplies a load of 600W.
The battery gets the other 630W as a charge current.
(Ohm's Law)
The (100A) windmill is making more amps than the (50A) load can dump.
The (50A) extra amps "go into the battery" and the battery overcharges.
The battery voltage goes up.
The C60 can not take enough amps and send it to enough load to keep a battery voltage under control, for your 1230W windmill.
There are options, but the best for you is probably 1 more C60 and another 600W heater element.
Re: Xantrex C60 (3.00 / 0) (#4)
by tmcmurran (t_mcmurran@yahoo.com) on Mon Oct 6th, 2008 at 03:18:50 PM MST
Ok, thanks.  Now I get it.  Kinda had me running around trying to find a round spot in the corner to hide in there for a bit.
You are the first person to offer a simple straight forward answer.
You have my thanks and praise :)
Re: Xantrex C60 (3.00 / 0) (#5)
by ghurd on Mon Oct 6th, 2008 at 03:41:35 PM MST
I believe it is easier to think in Amps, and then use Ohm's Law on everything.
Do not run out and buy a 2000W heater/resistor without using Ohm's Law, then Watt's Law.
It tends to backfire in the wallet region without some math.
Re: Xantrex C60 (3.00 / 0) (#6)
by tmcmurran (t_mcmurran@yahoo.com) on Thu Oct 9th, 2008 at 09:31:14 AM MST
Well it looks like the plan is starting to fall into place.  I will be running with 2 600 watt 12v heating elements for submersion use.  This should take care of the upper limits that the Whisper can put out in these fall/winter wind conditions.  But did have a strange thing going on yesterday when we took a run out to the other house to check in on things prior to this weekends visit/re-siding :(
The mill was in brake control and the controllers dump load was stone cold.  Batteries were fully charged though, and as soon as I put draw on the batteries the controller and the mill sped up and showed charge again.
Now I did go and drop in the optional LCD control panel last week, and I may have my upper and lower levels a little mixed up.  Problem has been only so much time to play with settings before needing to leave.  At least I will be able to sit and monitor things over a 48 hour period this weekend to see where it is all going wrong.  Think thats been my largest problem so far.  You really have to hate rushing things that you want/need to run properly for a week at a time with no intervention.
Xantrex C60 | 6 comments (6 topical, 0 editorial)
