PWM Switch # 3 | 9 comments (9 topical, editorial)
Re: PWM Switch # 3 (3.00 / 0) (#5)
by Flux on Tue Feb 26th, 2008 at 10:06:43 AM MST
Opto isolators can manage volts well enough but they are little use operating from shunts unless you use tricks to fool the voltage threshold.
Hall current sensors are excellent but a bit costly and greedy on power. They are probably justified to save all the hassle of using opto isolators with op amps and opto feedback.
Re: PWM Switch # 3 (3.00 / 0) (#9)
by BigBreaker on Wed Feb 27th, 2008 at 08:15:58 AM MST
Flux is right - the opto won't work as shown in the schematic.  The shunt will not provide the voltage drop for the opto's LED.
The pick up coil solution is complicated by the fact that it misses the constant current portion of the signal, like a transformer would.  If the current reliably dropped to zero at some point in the buck cycle, you could use that to rezero the sensor, but that isn't generally the case for bucks.
A Hall sensor or "going naked" might be your best bet.
PWM Switch # 3 | 9 comments (9 topical, 0 editorial)
