ups question | 8 comments (8 topical, editorial)
Re: ups question (3.00 / 0) (#4)
by dinges on Thu Feb 28th, 2008 at 07:39:14 AM MST
Try taping a small piece of stickytape over the hole of the piezo buzzer. That brings the noise down to a more decent level. No soldering or other electronic surgery involved.
Peter.
Re: ups question (3.00 / 0) (#7)
by Flux on Thu Feb 28th, 2008 at 10:44:35 AM MST
Most MSW inverters are square wave at 50% duty cycle, it works out that the rms and peak values correspond with a sine wave so they run incandescent lamps as for sine wave and the peak is the same as a sine wave for things that rectify and smooth to dc.
Assuming 110 ac will have a peak of about 154v then the 50% figure would give an average of 77v.
Most cheap meters read mean but are scaled to show the value as rms of  a sine wave.
Allowing for the form factor you should read somewhere just over 80v so that seems reasonable.
As others have said the simplest way is to compare light with a filament lamp against known 110rms.
ups question | 8 comments (8 topical, 0 editorial)
