........oztulesFlinders Island Australia
The axial version is far easier to build and you can adjust the cut in speed by simply altering the clearance between magnet rotor and stator. Once built you are stuck with the radial if your cut in is wrong. The thing is a pain to mount physically with windings around the outside and you must have no solid metal in the region of flux linkage.
It makes more sense to build the equivalent of a dual rotor this way with magnets inside and outside or with magnets in a drum on the outside and a spinning steel cylinder inside.
Before the days of neo it was virtually useless to build things like this so I can't see the logic of using neos in very poor designs where it costs more to get the same output. Everyone to his own choice as always.
Flux[ Parent ]
Why? dual rotors are expensive but more impotantly I suspect the cause of most of the failed gennys here is largely heat which would not be as bad a problem on this design. This design scales very easily and creating a more durable genny is also a consideration.
You are right in that the design will not allow for any adjustment after it is built. The only way to change it would be to tear it apart and rewind the coils. I do not see that it will be any more difficult to build then an axial or more expensive for equal power output. I would have to build a small one to test so that I could get an idea of what a large one will cost.....
<shrug>[ Parent ]
