A mono pole magnetic structure? [Comments Locked] | 37 comments (37 topical, editorial)
Re: A mono pole magnetic structure? (3.00 / 0) (#11)
by finnsawyer on Fri Feb 29th, 2008 at 08:46:24 AM MST
Sorry, but the magnetic field also obeys the dictates of the Special Theory of Relativity.  You think this thing could be built.  Perhaps it can't.  Perhaps it would take infinite energy to do so.  You can calculate the energy contained in a shell of charge by bringing infinitesimal amounts of charge onto the shell and summing (integrating) all the amounts of work or energy needed to do so.  Can you do a similar calculation for your monopolar magnetic sphere?
From a practical standpoint when you try to bring the last few magnets onto the sphere they will insist on flipping.  If you try to use some sort of machine to hold the magnets, the magnets will likely disintegrate as the individual magnetic domains flip causing strong stresses in the magnets.  Just because you can conceive of something doesn't mean it can be built.
GeoM
Re: A mono pole magnetic structure? (3.00 / 0) (#17)
by aimulti on Fri Feb 29th, 2008 at 05:48:56 PM MST
The mechanical problems of assembling the sphere have been worked out. It requires a fairly complex jig with hydraulic actuators and retracting sleeves. When you say the magnets will 'flip', do you mean physically or magnetically?
The mechanical flip can be stopped, as I said. The internal magnetic 'flip' or demagnetizing is a function of the B and H curve of the material. For 55MGOe NdFeB the ratio is about 7:1 so if the imbalance exceeded this ratio the magnet would fail.
In the proposed design the magnetizing force and demagnetizing force is kept in limit by the pinned flux.
The greater the contamination of the super conducting material, the greater the pinning and 'draining' of one side of the circuit.
The device does not require the addition of energy for containment, like a Stellarator or Tokamak, as it is a relative field block not an external field bottle.
A mono pole magnetic structure? [Comments Locked] | 37 comments (37 topical, 0 editorial)
