500 W motorconversion finished | 37 comments (37 topical, editorial)
Re: 500 W motorconversion finished (3.00 / 0) (#18)
by sPuDd on Fri Feb 29th, 2008 at 10:49:22 PM MST
(User Info) Atherton Qld Australia
Always top work from you Dinges :-)
Also, your posting is the first one where I have seen
HOW to get the windings IN and OUT of a conversion.
So far that step has been "...now rewind it.." which
was like leaving the money shot out of a smut flick :-p
Now it makes much more sense. I might even have a go
at my 250W blue boy that I quit on.
http://www.fieldlines.com/story/2006/6/23/94016/5550
Thankyou,
sPuDd..
Re: 500 W motorconversion finished (3.00 / 0) (#21)
by oztules (oztules__at__bigpond.com) on Sat Mar 1st, 2008 at 06:45:58 AM MST
sPuDd,
When I did my rewind, I wound three coils at once for a concentric wind pole. This introduces a few extra problems with trying to wiggle the coils into the stator slots.(the problems of slot fill verses terminating all the coils ends... I felt slot fill for three joined coils was the lesser evil)
I had difficulty with the first coil of the three, worse with the second and didn't bother even starting the third until I came up with a better way.
What I found was the greatest help was to get 2 pieces of your slot paper... say 2"  wide x the length of the stator, and tape them to the inside of the stator so that only the slots you were currently interested in are exposed (dont worry about the inner slots between, just the 2 slots your working on and outside them.)
Your coil will be too wide to bother falling into the inner slots.
When the paper is in place, put the coil inside the stator, and the wires will almost fall into the slots because there is nowhere else to go or drop into.
Once I discovered this, it took no more than 2-3 mins to put 75turn coils into their respective slots, and was just as easy for the last coil as the first.
Without those pieces of tape and paper, it was absolute hell, and maybe 10-15mins per slot. The difference in ease is astronomic.
go for it
........oztules
500 W motorconversion finished | 37 comments (37 topical, 0 editorial)
