What is the criteria for a good Question or posting? | 20 comments (20 topical, editorial)
Re: What is the criteria for a good Question or po (3.00 / 0) (#14)
by twombo on Wed Feb 6th, 2008 at 10:36:27 AM MST
So... What is  the Question?
12 responses... and no specific question yet!
Let's try baby steps here!
mike
Re: What is the criteria for a good Question or po (3.00 / 0) (#15)
by feral air on Wed Feb 6th, 2008 at 12:17:58 PM MST
The question is, "How do you form a good question?"
Re: What is the criteria for a good Question or po (3.00 / 0) (#16)
by twombo on Wed Feb 6th, 2008 at 04:19:30 PM MST
Sorry, man!
I hadn't read "Trying Something New" by Tom W, an antecedent post it seems.
I understand now. I was waiting impatiently for a question!!!
How about:
What is the present condition?
What is the desired condition?
What do you propose to do.
Studying the technology enough to have a basic understanding is the dues that must be paid up front is the price of admission, if you will! No one expects perfect from the new person. It is  cooperative venture in places lie this, so, to ask for help, one must take the responsibility to make a strong first step.
mike
Re: What is the criteria for a good Question or po (3.00 / 0) (#17)
by TomW on Wed Feb 6th, 2008 at 05:53:14 PM MST
mike;
Pretty much my point. Folks just need to show willingness to try on their own at least a step or 3.
This field combines several non trivial skill sets to accomplish useful results. None of them compatible with the "fast food" mentality many seem to have in this world now days.
Re: What is the criteria for a good Question or po (3.00 / 0) (#18)
by GeeMac (foxunc@telus.net) on Wed Feb 6th, 2008 at 07:14:30 PM MST
The asker wants to get a few solar panels and run a 12 or 24 volt pump to deliver water to a garden showpiece waterwheel. The water wheel is not meant generate power.
He doesn't know where to begin.  I have told him to start small with a solar panel.
Then add a small charger and add a battery or two. Then add 200 or 400 watt inverter to drive a small pump. (Needs to pump about 1.5 gallons a minute.)
What size(electrically) solar panel do you recomend?
How many panels are needed?
A small charger should handle the job - I've seen small chargers for about $29.95
How many and what type of battery should he buy?
If he can only get a 110 volt pump then a 200 watt inverter should be enough.
What say you, the experts?
GeeMac
Re: What is the criteria for a good Question or po (3.00 / 0) (#19)
by feral air on Thu Feb 7th, 2008 at 08:55:38 AM MST
Even though I'm not an expert...
Does it need to run 24/7?
If not, you can get fairly inexpensive solar pond pump kits just about anywhere. One probably won't move 1.5gallons a minute but you could get several and run them in parallel....unless you need significant pressure too.
Just a thought. take it easy
Re: What is the criteria for a good Question or po (3.00 / 0) (#20)
by luv2weld (luv2weld at hughes dot net) on Thu Feb 7th, 2008 at 09:26:55 AM MST
Geemac,
Why are you trying to hi-jack his thread??
What does this have to do with the original subject of this post??
Did you send the same private email to all the other people that answered this
thread as you did to me???
Why are you trying to be byndhlpngs secret protector???
Yeah, I know I just pissed you off!!! And I don't care!
Both of your postings in this thread are completely uncalled for and
off-track.
Go back and read the title of this thread.
Ralph
What is the criteria for a good Question or posting? | 20 comments (20 topical, 0 editorial)
