Use external charge controller rather than internal inverter charge controller? | 10 comments (10 topical, editorial)
Re: Use external charge controller rather than int (3.00 / 0) (#2)
by crashk6 (crashk6(at)solarstormtechnologies(dot)com) on Wed Feb 6th, 2008 at 10:19:50 AM MST
Heed Woof's advice on the turbine.. you will have a problem if it has no electrical load to keep it's speed under control. It needs to be loaded under most any normal circumstance.
Secondly on the load control,
Do NOT use a load control between the batteries and inverter. The inverter will only draw from them when needed anyway. On Xantrex equipment in that power range every necessary function for the inverter battery interface is all done in software.
You stated you contacted Xantrex to ask this, but did not state what advice they gave. I imagine it was something along the lines of "That application is not covered under warranty" and there would be a reason for that!
Thirdly, the inverter does not contain a charge control for any charging source per se, what it does have is a battery charger to charge from ether the utility grid or a backup generator.
This seems to be an extension of one of your earlier posts http://www.fieldlines.com/story/2007/12/16/155529/12
Where people gave you some information on charge controllers already.. re-read it.
If you still can not get a picture in your mind look for drawings of these types of systems.
www.homepower.com
Would be a good place to start for very GOOD system schematics that would give you a feel for the equipment your working with. Mind the schematics may not be your exact situation however you will start to see the similarities.
Short of that you could have a Xantrex engineer fax or email you their recommended connection practices in schematic form for your application.
You have gotten lots of explanation from folks here but a visual aid may be in order so have a look at HomePower. The subscription is worth it, in fact get some back issues. They come in print and digital.
crashK6
Re: Use external charge controller rather than... (3.00 / 0) (#7)
by dlenox (dlenox@briery.com) on Wed Feb 6th, 2008 at 02:09:35 PM MST
(User Info) http://www.briery.com/wind_turbine
Unfortunately, I double checked my inverters specs and confirmed my inverter will only accept 44 to 64 volts, I had looked at so many inverters initially that I should have double checked this. So for my system this question ended up being a moot point.
But as a general statement, I think that using an MPPT charge controller 'could' be used if one existed were versatile enough for wind turbine (rather than solar). Assuming that enough of a load were put on the wind turbine to keep it in check.
Another assumption is that there is always a diversion load connected to the turbine output so that at 'some' point it kicks in...
Dan
Use external charge controller rather than internal inverter charge controller? | 10 comments (10 topical, 0 editorial)
