Absorber plate for diy flate-plate collector | 14 comments (14 topical, 0 editorial)
Re: Absorber plate for diy flate-plate collector (3.00 / 0) (#12)
by mbeland on Tue Feb 12th, 2008 at 05:52:04 AM MST
Hi fcfcfc, I have received only very limited information so far about this quote which is rather informal. It stated: 4 indirect panels of each 20 evacuated tubes panels which will generated a load of 100,000 btus on a good day with 2 80 gallons storage tank with double heat coils. Cost of 4 panels, 2 storage tanks workstation is approx $8000.00Can FOB(Toronto) shipping extra without installations. Design will included overheating during summer as system will heat domestic hot water and space heating during winter Do you think this is a fair price? I guess it depends what these tubes are... Martin
Eau, soleil, le vent
Re: Absorber plate for diy flate-plate collector (3.00 / 0) (#14)
by fcfcfc on Tue Feb 12th, 2008 at 10:59:22 AM MST
Hi Martin:
Well, lets say the evacs are 1K each, I.E. $4000 leaving $4.000 for two 80 gallon tanks with heat exchangers and some pumps, controller maybe. That seems a bit steep. You could pick up two 80 gallon Whirlpool electric water heaters at Lowes for about $750 total (don't connect electrically), an external plate exchanger for $200 or less, two circ. pumps one cast iron and one bronze and solar diff controller for $350 or so, then fill valves, expansion tank, pressure/temp gauge, pressure relief valve, other misc for $500 or less. Then just your piping and insulation and some other small misc.. so we are at $5800 including the collectors.
