Absorber plate for diy flate-plate collector | 14 comments (14 topical, 0 editorial)
Re: Absorber plate for diy flate-plate collector (3.00 / 0) (#3)
by mbeland on Thu Feb 7th, 2008 at 09:29:27 AM MST
Thanks all, My house is 28 x 40 basement, two main floors and an inhabited attic. The house is currently heated with a radiant floor hydronic system using electric boiler. That is why I considered water collectors instead of air collectors. We also have a wood stove for back up. I know that evacuated tubes are more efficient but lends themselves less to diy. Martin
Eau, soleil, le vent
Re: Absorber plate for diy flate-plate collector (3.00 / 0) (#5)
by GaryGary (gary@BuildItSolar.com) on Thu Feb 7th, 2008 at 07:54:47 PM MST
(User Info) http://www.BuildItSolar.com
I don't want to start this whole discussion on evac tubes vs flat plates up again, but for typical winter applications they have essentially equal performance.
You can look up the numbers on the SRCC site, or use this calculator, and plug in your conditions to see which does the best for your situation:
http://www.builditsolar.com/References/Calculators/Collector/ColEfic.htm#efic
That said, if you don't go with the premade absorber sheets, its hard to DIY a collector that is as good as a good commercial flat plate.  But, its not really efficiency that matters as much as dollars per BTU -- if the collectors are cheap enough you can just use more area to offset the slightly lower efficiency.
Gary
Re: Absorber plate for diy flate-plate collector (3.00 / 0) (#7)
by mbeland on Fri Feb 8th, 2008 at 07:17:39 AM MST
Thanks for your comment. I have looked briefly at srcc ratings but I don't know the brand names and make of flate-plate collectors vs evacuated tube collectors. Nevertheless, these ratings seem to be for hot water systems (am I right?), not for water space heating. The ratings would then consider the global performance year round, whereas for space heating the most part of the demand would be in the winter where evacuated tubes are theoretically better. On the other hand, since space heating with radiant hydronic systems use water at temperatures that are lower than domestic water heating, there may be a trade-off here. Will the calculator show me where is the tradoff? Martin
Re: Absorber plate for diy flate-plate collector (3.00 / 0) (#9)
by GaryGary (gary@BuildItSolar.com) on Fri Feb 8th, 2008 at 08:31:44 AM MST
On the SRCC site they have ratings for whole systems, but they also have ratings for each individual collector they test.  On this page, the link is labeled: "Directory of SRCC Certified Collector Ratings".
http://www.solar-rating.org/RATINGS/RATINGS.HTM
They give collector output for Categories A through E  -- categories C and D would be typical of winter space heating applications.
When comparing two different collectors, you have to be careful to divide the heat output listed by the collector area to get an output per sqft.
The section on each collector labeled "Collector Materials" makes it clear what kind of collector it is.
A bit more on using SRCC stuff:
http://www.builditsolar.com/References/Ratings/SRCCRating.htm
The calculator that I mentioned in the post above allows you to enter a specific set of  weather conditions, and and a particular collector -- it then gives you the heat output per sqft and the efficiency.  You can run it for different types of collectors to see how well each works.  The data it uses is right out of the SRCC ratings directory mentioned above.
When you do these comparisons, look at weather for your whole heating season.  In our area, a significant fraction of the benefit comes in the fall and spring when we are still heating, but the conditions are milder.
Gary
