Micro-Solar LED Desk Lamp | 40 comments (40 topical, editorial)
Re: Micro-Solar LED Desk Lamp (3.00 / 0) (#11)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Thu Feb 7th, 2008 at 04:06:11 PM MST
Claude;
 I too would like to have a look at that 555 PWM circuit. I've been working with linear pots to adjust LEDs. I'm starting to work with some of the newer K2 LEDs that are rated up to 3.72Vdc and 1Amp.
With respect to G-s post. I'm with you, but I would scrap the SLA and go with a NiCd set. I have been testing these and can run a 12Vdc LED set on 10.80Vdc and they light up with almost as much brightness.
Plus they can be run down to near empty >20% charge left and come right back up.
Re: Micro-Solar LED Desk Lamp (3.00 / 0) (#12)
by americanreman on Thu Feb 7th, 2008 at 06:55:19 PM MST
Got that right, small means small...you don't need 12v to run leds, it's a waste.
Go for 3 volts instead and use small encapsulated panels in series and parallel for your requirements. Nicads are the way to go, charge them and let them run completely down, recharge them again. If you match your solar output to your daily usage you can just let them run down (like outdoor solar garden lights). Nicads can cycle everyday for 3 or 4 years or more without replacement.
You could get the system down to little money out of pocket, especially if you score cheap garden lights and use the batteries and leds out of them.
Re: Micro-Solar LED Desk Lamp (3.00 / 0) (#14)
by claude on Fri Feb 8th, 2008 at 06:09:12 AM MST
see this one: http://www.dprg.org/tutorials/2005-11a/
or, http://www.uoguelph.ca/~antoon/circ/pwm555.html
It's simple to make. One thing is that it won't go down to 0% or up to 100%. You could adjust (by using germanium type diodes) the output in between 2% -- 99 %. It's good enough for me.
I made it and used it along with a LM117 voltage regulator and a MOSFET-based current limiter and so I got a regulated voltage&current driver + PWM adjustment. Sweet.
It all looks like this (to the right, the 555-based PWM):
Re: Micro-Solar LED Desk Lamp (3.00 / 0) (#15)
by claude on Fri Feb 8th, 2008 at 06:11:47 AM MST
Oh, I forgot, the three pins on the far side are for connecting the 50K Pot.
Claude
Re: Micro-Solar LED Desk Lamp (3.00 / 0) (#16)
by Bruce S (bruce(dot)stahl <at>gmail (dot)(com)) on Fri Feb 8th, 2008 at 07:04:50 AM MST
Claude;
 Thanks for the circuits. Will be another one to try out. I like nice/simple and easy :-)
Will bread board it up for a good test.
Thanks Again
Micro-Solar LED Desk Lamp | 40 comments (40 topical, 0 editorial)
