Guys,
Everything needed is already here in more quantity than I care to admit. Except for one of Claude's fancy circuits.
A better plan for the use of power would make the numbers look better.
About 5X the money would get 15X the power.
Catch 22. There would be a LOT more power available in the summer, when the lamp isn't needed as much.
Anglepoise and CFL. I put rubber bands with the lamp springs.
LEDs on less than a 12V system is a complete waste of solar cells and power.
I need this lamp to be working when I need it. Draining a couple AAs and trying to see with 80% dead cells isn't going to do me any good.
Besides, there are more than enough nicds here to build a 12V 50AH pack.
The lamp will be a story by itself. If the lamp is on, and the battery is below 12.22V, then a tiny 12V transformer gets grid power to help supply some of the lamp power. It won't charge the battery because it doesn't quite make enough ma to power the bulb, but it will keep the battery from getting too low or me from being in the dark.
It will be able to use every drop of available RE.
Geoff must live on the moon!
