Fireplace vents | 9 comments (9 topical, editorial)
Re: Fireplace vents (3.00 / 0) (#1)
by Birdmmjb on Thu Feb 7th, 2008 at 08:53:39 PM MST
Hi.  I'm no experte on the subject but my experince with a fire place with vents was that they will work you to death feeding them with very little heat gain except for the heat you generate cutting the wood.
After trying to heat my house with a fireplace like yours I put in a Buck stove.  What a difference it took less and 1/4 of the wood per day and heated the entire house (sometimes too well) where we were not even keeping the living room warm before.
Just an little bitty tippy.
Jan
Re: Fireplace vents (3.00 / 0) (#2)
by TomW on Thu Feb 7th, 2008 at 09:46:40 PM MST
Bird;
Pretty much exactly what I was going to say. Fireplaces suck as heaters unless you like cutting wood and feeding the thing. Some improperly set up units are a net loss on heat from drafting out room air, too. I would at least go with an insert.
Fireplace vents | 9 comments (9 topical, 0 editorial)
