Wind powered swimming pool | 12 comments (12 topical, editorial)
Re: Wind powered swimming pool (3.00 / 0) (#5)
by Flux on Sat Feb 9th, 2008 at 02:45:33 AM MST
I agree with JMK that you will need an incredibly good wind site to keep up with your pumps.
If you could get dc pumps then you would be in with a far better chance. The cube law of a centrifugal pump matches wind power fairly well. A dc pump would be working much of the time even though it would be rarely on full rating. An inverter driven ac pump intended for constant speed would be a poor match.
Re: Wind powered swimming pool (3.00 / 0) (#6)
by Flux on Sat Feb 9th, 2008 at 02:49:08 AM MST
Perhaps I should have made it clear that my scheme would not include a batter in normal operation. You could still charge one during windy periods and extend pump time in low wind periods, but the turbine would directly drive the pump at variable speed normally, using all the available wind.
Re: Wind powered swimming pool (3.00 / 0) (#7)
by frackers (g8ecj at *nospam* gilks dot org) on Sun Feb 10th, 2008 at 04:34:03 PM MST
I'm going for the battery to smooth out the availability of power - rather than the norm of storing the energy until I want to use it and dumping any excess, my scheme is to store it until I have a useful amount and use it automatically there and then.
In this manner (so goes the theory!!) if I get 4kw/hrs of power in a day then my pump will run for about 4 hours, spread throughout the day as the battery bank gets sufficient charge. This is certainly enough to keep the water clear.
The beauty of the system is that the timing is not critical at all - in fact if I go for a couple of days of no wind, so I get no filtering of the pool water, then it's no big deal.
I'm making 2 overrides in the pump controller - one is if the solar controller (which looks for the solar panel to be 4c higher in temperature than the pool) wants to run its pump then it will use the inverter power if its available. If I have no wind then I could end up with a pretty cold pool so I'll have a manual override that will use mains power if necessary and just use the filter pump as the dump load.
The second override is the dosing of chlorine etc which is handled by another controller (which has various solenoid operated valves). This will be set up to run for one hour each night. If there is battery power then the pump will already be running, doing its job as a dump load. If not then mains power will run the pump.
This area is where a more intelligent controller will be useful - to predict that the chemical cycle is due in half an hour so allow the battery bank to charge for those few extra minutes or if the pool is getting cold then automatically use mains for the solar pump to push the 45kw of heat into the pool (its amazing how quickly 50sq.m of bespoke neoprene solar collector warms things up!)
Concerning the use of DC motors - I seriously looked at that option but whilst it works great for the wind genny, its a large capital cost and the extra cost of a mains charger (or 24v 40amp supply) to provide mains backup really is a deal breaker :-(
Wind powered swimming pool | 12 comments (12 topical, 0 editorial)
