straightening copper wire | 8 comments (8 topical, editorial)
Re: straightening copper wire (3.00 / 0) (#4)
by coldspot on Sun Mar 2nd, 2008 at 10:20:41 AM MST
Very NICE work-
 From the picture, on the right side it looks
 like the varnish is cracking and falling off?
 I've used clear fingernail polish and
 spray can clear to re-coat this on my recycling
 of wire. What are you doing???
Re: straightening copper wire (3.00 / 0) (#5)
by bob golding (photoman290 at yahoo dot com) on Sun Mar 2nd, 2008 at 10:50:42 AM MST
i doubt the enamel is cracking off unless it has got very hot. its tough stuff. unless it is very old  lacquer covered wire. if you go into a motor rewind shop and see what they do to wire you will know what i mean. if it is  wire from an old transformer or something the varnish  it was dipped in, to hold the windings together to prevent noise, might come off,but not the enamel. good idea by the way.
cheers
bob golding
Re: straightening copper wire (3.00 / 0) (#6)
by dinges on Sun Mar 2nd, 2008 at 12:53:34 PM MST
I have noticed when taking apart one particular motor that pulling wires loose from eachother (they were varnished to eachother) took the insulation of the wires and left one of the wires with bare copper.
Apparently, the baked/dipped varnish adhered better to the wire lacquer than the lacquer adhered to the copper itself...
This was another confirmation of my plan to never ever bother with re-used copper wire. Others seem to get good results though. But apart from living on a (nearly-) deserted island (Hi Oz ;) ) I think it'd be much wiser to spend a few $$ and buy new wire.
At least, it's what I do.
Would be a shame after having spent dozens of hours building a generator having to arrive at the conclusion that it doesn't work because the wire insulation failed.
Also notice that the back-and-forth bending of the copper wire stress hardens it. It becomes harder and more brittle and may break when bent a few more times again. And become more susceptible for fatigue.
Anyone who knows me know I'm a scrounger, but sometimes one needs to use the best quality materials available. In the case of generators, that would be copper wire, magnets and epoxy. One could compromise a bit on the other parts, I suppose.
Peter.
Re: straightening copper wire (3.00 / 0) (#8)
by wdyasq on Mon Mar 3rd, 2008 at 05:07:19 AM MST
Used bearings ....
straightening copper wire | 8 comments (8 topical, 0 editorial)
