straightening copper wire | 8 comments (8 topical, editorial)
Re: straightening copper wire (3.00 / 0) (#7)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Sun Mar 2nd, 2008 at 04:23:11 PM MST
well sum good comments.   at first i was afraid i might strip or tear the enamel off the wire.
  but after a while i started to just try and get the enamel off.
  so i would understand how much it took to remove.
 so bob your right its very tough stuff that enamel.
  so considering the wire hasent been overheated in the past . and looks good
  then i dont see a problem.
  but after i wind a coil i test it every way i can.
 it was great when i made the rotor as i could test with rotor in lath and watch the ac out.
 but now rotor is fitted to the gen i can only test with a meter .
 i am not going to be building gens all my life but would love to have a scope.
  i find if i had a spare rotor i could test things such as coils.
  but having neos  tied up on a steel plate would be a luxury.
  so will wait till i build my next rotor .
  in the pic i can see the lighter colour bit it dos look like a bit missing.
 but that was a bit test wire i was using when playing with and setting the rollers.
  as yet i havent tried to repair enamel damage.
  there was a coil i wound that had a wee bit missing.
  but as the wires it was laid up to were good i done nuthing.
  once the coils are potted only bad over heating will make the coils lose there insulation .
  as this is all a learning curve for me. its good i dont need worry about what i do with expensive new wire.
  and peter yes i found a motor that was the same as you talk about.
 it was a pain to try unwind. it to was pulling off the enamel.
  but as it was a fast spinning type thing. then that's why it had varnish on it i suppose .
 looks like transformers are better.  or the field coils on the stator .
  but the fact i found one thing pulling off the enamel. dident stop me in my tracks .
  my motto is .IF AT FIRST YOU DONT SUCCEED THEN TRY AND TRY AGAIN.
  i don't intend to build a wind gen with copper wire that's no good .
   far from it . i hope the wire i am using will be better than the cheap chinese
  stuff that is being imported from Asia.
   nothing against  the chinese   as i do love there magnets.
   i think there trying to figure out what quality control means .
    yes sum wire is junk but that can be put in my scrap box.
    my wife has that nail varnish stuff .
  maybe i can bye her half a gallon for her birthday.
   who knows.
straightening copper wire | 8 comments (8 topical, 0 editorial)
