Solar Powered Electric Snail Fence | 26 comments (26 topical, editorial)
Re: Solar Powered Electric Snail Fence (3.00 / 0) (#24)
by Nothing40 (phattymo (at) gmail (dot) com) on Thu Mar 6th, 2008 at 01:01:09 PM MST
(User Info) http://www.users.qwest.net/~ptaylor/
If low voltage DC isn't enough,maybe you could try a small inverter,wire the output directly to the tape. -On second thought,add a large resistor in series with the tape,to limit the current.You don't want to cook the snails,or start a fire.
If DC would work,that would be the simplest solution.You may need to experiment a bit,and find a voltage that's high enough,12,24,36? I've no idea. But,all you would need would be a battery for storage,and some solar panels. I don't think either would have to be very large/expensive.
Solar Powered Electric Snail Fence | 26 comments (26 topical, 0 editorial)
